RCU Forums - View Single Post - How to??? Control surface removal
Old 03-29-2004 | 09:59 AM
AJF--2
My Feedback: (119)
Default How to??? Control surface removal
I need to recover a giant bipe (lots of hinges). It has Dubro plastic hinges epoxied into all of the surfaces. What is the best way to remove the surfaces? I was thinking of Dremeling the ends off the steel pins and removing the pins and replacing it with a long piece of music wire when the time comes to put them back. Then I noticed the gap is too small and I will also be grinding away at wood. How would you go about handling this? Thanks in advance.
