RCU Forums - View Single Post - Hyper 7 diffs not lubed.
Old 03-29-2004 | 10:55 AM
Sherak's Avatar
Sherak
Default RE: Hyper 7 diffs not lubed.
ORIGINAL: grahama89
Anyone else wondering A good starting setup I find is 3000wt Front, 5000wt Center and 10,000wt rear. These are all Silicone Diff Lock Oils. And yes you could run shock oil in there but it is so thin that the car would handle like crap and the diffs would need rebuilding every session.
What the deal there Alex man, you say 10k rear, Ive never heard anyone recomend any higher than 1k, even when you check out the pro's set up sheets from some of the nationals (on CML's web site) you rarely see above 1k in the rear............. 10k would induce silly wheel spins on the rear tyres during turns making turning less predictable would it not?
