RE: Bounce on Landing >.<
With wire landing gear, you really have to finesse your landings to keep the plane from bouncing. Best suggestion I can make is slow it down as much as you can, if you can try and fly along about a foot off the runway untill it just drops of its own accord. You also could try a smaller nose landing gear wheel, try and give the wing negative incidence with the plane sitting on the ground. Also release the elevator as soon as the plane touches down.... HTH
Andy
