RE: CHARGING LI-POLY - NEED SOME HELP
it's holding a steady charge of 12.32 -.33 so far
I did get a nice spark off of it when I was fitting it with new connector (came with no connector)[:@]
I was told that Hobbico Quick field charger MKII will hold the Li-poly charge @ 1000mA no matter how high you set it to.
Why do people still recomend using Hobbico for Li-Poly, I read the little manual for the charger and they advise against charging Li-Poly. They say that the battery types are not the same yet I heard so many people say its OK to charge Li-poly
