THE FIELD BOX FROM HELL! aka The Ultimate Field box!
Al,
If you look closely at the picture (click it to get the large version) you can see the battery to the left of the fuel tank it is not concealed in any way. You can also see a little bit of the pump where it protrudes out of the long bar of blue foam to the top left of the picture. Look even closer, and you can see how the plumbing is connected to the 2 dubro fueling valves.
