RCU Forums - View Single Post - Loading of Control Surfaces?
Old 03-30-2004 | 07:21 AM
OVER WORKED
Default RE: Loading of Control Surfaces?
The force required to deflect any control surface is determined by the dimension of the control surface, the angle of deflection and the velocity in relative speed. To calculate the required servo strength, the geometry {mechanical advantage / disadvantage} of the linkage must also be considered. This is a very complex series of calculations best done with a computer. There is a shareware program called RC calculator that will get you very close.
