RCU Forums - View Single Post - THE FIELD BOX FROM HELL! aka The Ultimate Field box!
Old 11-27-2002 | 02:14 AM
  #106
Buz_Bo
Default THE FIELD BOX FROM HELL! aka The Ultimate Field box!
Billy, I agree. You can carry everything you need in one enclosed unit. These things are great. I found mine at Home Depot for 29.95. What a buy. Here is a work in progress picture of the bottom fuel compartment. I have two 64oz separate containers because they fit without having to modify anything. Another good thing is if I decide to start using 4strokes along with my 2stokes I can carry both types of fuel in one setup. When you look at this picture remember this is the first stage of setting it up. You'll see a plastic bag and foam around my battery and two containers. Once the foam hardens I'll remove most of the bag and trim down the foam. This was done to hold everything in place. The fuel bottles and battery are wrapped in plastic so the foam will not stick. I plan on being able to remove the battery and containers when needed after this process is complete.
