RCU Forums - View Single Post - Split elevator setup
Old 03-30-2004 | 04:03 PM
JCOKEEFE
Default RE: Split elevator setup
I tried mixing split elevators (one servo per elevator) with my Eclipse and
mixing with one elevator half on channel 2 and the other elevator
half plugged into channel 6. It works fine with one exception, if you want to trim
your elevators, only the elevator plugged into channel 2 will trim. The
channel 6 (slave) elevator remains stationary. I opted to use the
y cable with servo reversor.
