ORIGINAL: cumn thru
Thanks Mike, On the last one I had washers doubled up and as near as I can figure it equalled about 3 degrees give or take. At that point it seemed like it could use more, not knowing just how far the wood compressed and cancelled out the angle. So I guess I'll start with the 3 degree plate and see what happens. Good to hear from you, Joe
Joe, just in case, you could stack up the plates to give you more than 4 deg, and also a combi of side thrust and up/down thrust. Those plates are really good stuff. Wish they will come up with larger ones for >.90 size engines.
