RCU Forums - View Single Post - Loctite and Blind Nuts
Old 03-30-2004 | 09:11 PM
Jim Thomerson
Default RE: Loctite and Blind Nuts
I use the blue locktite, and run a tap through the blind nuts to clean them out after I remove the bolts. It is no fun putting a bolt in and pushing the locknut out. I also solder a brass plate or something over my blindnuts to be sure they don't come loose or turn. That's on ones I can't get to should they come loose.
Jim
