RE: Sig 1/6th J3 Cub
slowly back to work on the cubby after a long time off. i needed to shorten the nose by 5/8" to accomodate the OS30FS i plan on using. also, while i was at it, i incorporated the 3 degs. nose down thrust that is shown on the plans into the fuse structure vs. angling the engine bearer as the kit specifies. i also glued in the 1/4" balsa sheeting "fill" pieces into the nose. now time to apply the 3/32" skin to the forward fuse.
