RE: EXPONENTIAL SETTINGS
If the angular displacement at both ends is the same for a given movement of the pushrod (that is, the hole the pushrod uses is the same distance from the hinge line at both ends) the control surface should (should!) move through the same angle as the servo arm throughout the whole travel, even though,as the angle changes, the actual angle it moves is not constant with the pushrod movement.
Probably!
-David C.
