RCU Forums - View Single Post - On Off Switch Solution
Old 06-21-2002 | 06:18 AM
KeithB's Avatar
KeithB
Default On Off Switch Solution
I too have always mounted my switches where forward is off. With a low wing plane it would be easy to accidentally turn the switch off when holding the plane while running up the engine.
As far as the failed switch issue goes, I've never heard of one of these switches failing and causing someone to loose an airplane, though it obviously has happened or we wouldn't be having this discussion. Is this problem really that prevalent?
Keith
