RCU Forums - View Single Post - Loctite and Blind Nuts
Old 03-31-2004 | 11:17 AM
gnyberg's Avatar
gnyberg
Default RE: Loctite and Blind Nuts
ORIGINAL: Dsegal
Just a thought, but is your propeller balanced?
Yes, but I am still breaking in the engine and it idles pretty rough.
The firewall is doubled 1/8-inch plywood. I seemed to be crushing in the small flat washers I had used to shim for right thrust - may have limited tightness. Replaced washers with thin shim of aluminum all along left side of mount, allowed more torque/tightness.
I put a small amount of blue loctite on each once also... if they don't hold now I'll be surprised!
Thanks all for the advice.
-Greg
