RE: u-can-do 60
Mat..
Just opened the box really.. simular to UCD...bit thinner section to airfoil, all laser cut frame....comes ready to go either way with internall pull/pull setup...or servos rearwards..helps no end on your balance requirements...which,in turn, is dictated by the hardware you put up front.
All pull/pull fixtures and fittings are supplied,as well as rods should you go aft with your servos,much more ' open ' construction than UCD, much high grade, thin ply.
Vert & horz stab are constructed with brace point strengthening already in place,should you wish to brace them with the steel cable & fittings ,supplied..!
The more i go into this the more superb it seems..!
The prop driving face is to be 135mm from the firewall, same figure for c of g from LE
Slight taper to wing chord at tip,huge controll surfaces
Ali Mashinchy, ( of " Al's Hobbies "...London, fame ) one of europe's top display pilots has his photo on th box and was involved with " YT International " to create this and a couple of other freestyle/3d kits..dazzling stuff..
You guys should be able to get one of these for $249.00... unbelieveable..!
More later,Dave.
Just a couple more pic's of the internals this time ..looking back to the pull/pull provision...
