RCU Forums - View Single Post - Wattage MAD MAX
Old 03-31-2004 | 07:26 PM
jsn
My Feedback: (8)
Default RE: Wattage MAD MAX
Fun little plane! mine is bone stock, 800 mah wattage batts, wattage 15amp speed control 4 hitec 55's, AUW is 15oz. The plane is very easy to slap together and everything BUT the landing gear is fairly tough. It's really not a 3D plane though... it's almost got enough to hover... it won't tumble well at all, snaps are big and ugly and it won't knife edge(lack of power) it will slow fly nicely,roll rate is quick, harriers are fairly solid with some rock,spins are OK,loops are nice and tight with ele to flap coupled, flat turns are easy as are stall turns... the rudder has good authority. it moves out fairly fast WOT and is a BLAST in the wind...10 to 15 mph is when it's the most fun! the plane is more for sport flying...plenty of get out of trouble power just not enough for 3D, I've had a bunch of fun with this plane at my son's school yard. if you like the way the CM flew...the mad max will not disappoint you.
John
