RE: adding weight to a 4* 60
Sometimes you can mount the engine a little farther forward in the engine mounts to help with the CG. Also, when building a plane, it's a good idea to check CG before covering it. At that point it's easier to make changes.
Also, wooden props are lighter than the nylon ones. That's an ounce or two there.
