Guess this thread got interupted~ Ill ask again if anyone wants to help out. thanks.
quote:
ORIGINAL: copster
Ok guys.. I'm going to buy a UCD 46... This is what I plan on using: OS .70 Surpass II, Hobbico CS65 Servos and the Futaba S3010 for Throttle, an APC 14X4 Prop. I will also be using a Remote Glow igniter..... Any reason I should be changing before I buy? Thanks in advance for the info...
Personally, i really dont like hobbico servos, the quality for a 3d airplane is not there.
Definently use a micro servo for the throttle for weight savings.
Have you bought anything yet? The O.S 70 is a great running engine (i have 2) but they are heavy. My Satio 1.00 wieghs the same and puts out WAY more power. If you dont have an engine yet, buy a satio .72, they run just as good, about the same power, maybe a little more, but are almost 5oz lighter.
Go to Chief aircraft for the ucando, they got um for $119.99!!!
But your setup you got listed will work just fine.
David
