RE: corona problem please help
Ralph,
I have used a drill bit that is slightly larger than the set screw (but not big enough to hit the threaded hole!) and then used a larger allen wrench pressed in there to pull it out.
use a little heat at the same time to warm up the locktite, Should do the trick
Shotgun
