RCU Forums - View Single Post - 2 Stroke Engine Priming
Old 04-01-2004 | 04:07 AM
Funfly123
Default 2 Stroke Engine Priming
Can anyone suggest the best way to prime a fully cowled engine. The engine is an ASP 91 and it is side mounted, the fuel tank is mounted within the fuselage on the same center line as the carb there is no access to place your finger over the carb and turn the prop at the same time.
Many thanks in advance
