RCU Forums - View Single Post - I think some things wrong
Old 04-04-2004 | 08:51 AM
KLRico
Default RE: I think some things wrong
Are you talking about the swashplate moving, or the blades themselves when the rotor is static?
From the rear, the swashplate should tilt in the same direction as the stick on the transmitter... If it doesn't, double check your Tx to be sure all mixing is off and the Rx to be sure the servos are plugged into the right spots.
