RCU Forums - View Single Post - Rear Diff Problem
Old 04-04-2004 | 07:21 PM
vizaracer's Avatar
vizaracer
Default RE: Rear Diff Problem
check the dogbone to see if the little things on the end work and if they spin. to help diagnose the problem, get the truck running and lift it in air and let the tires move, then look at the bottom and see if the dogbone is spinning. if it is, then there can be a problem that is after the the center rear dogbone. if it doesnt spin, the problem is before the dogbone.
