RCU Forums - View Single Post - Crystal Swapping.. Again
Old 04-04-2004 | 09:40 PM
  #73
mr_matt's Avatar
mr_matt
My Feedback: (10)
Default RE: Crystal Swapping.. Again
ORIGINAL: Jim Branaum
I hope that clears up my comments for you.
Yes it does, and I did not take it as an attack.
And just to clear up some things. The Model Avionics system is for surface use only. Planes are an entirely different animal, because of the 3d maneuverability.
The other system, well I do not know. If you only fly simple trainer type aircraft, and you are careful with your TX antenna, it might work. But not as a hobby type usage. The automous thing is a canrad, he could just leave that part out and it would be within the rules.
IMHO, the reason it has not been done by the radio manufacturers...the current stuff works OK, and a new SS radio would be very expensive to make, with a limited market. Same exact reason you do not see any mass market Asian turbines, and likely never will.
