RE: Need help setting up receiver in EasyStar
Thank you Dr. Kiwi!!
Your advice is very helpful. You've answered everything, with one exception. The three wires coming from the esc are all yellow, and they are soldered straight into the circuit board in a straight line. I'm assuming the one that connects to a ciruit terminating at the crystal is going to be signal. The other two aren't as easy to trace. Dare I assume that since they've put signal at the bottom that the other two are in the correct order? If I botch it--say putting positive into signal--would that kill the receiver? How can one test the esc to see which wire does what?
Thanks in advance. Looking forward to finding out that the amperage of the esc is too low for the 400 motor. . .
Steve
