RE: Spark Plugs
I agree with the chex. cold spark plugs and hot spark plugs only to descrip the spark plugs heat range.
the heat range is a measure of the spark plug's ability to remove heat from the combustion chamber. The heat range measurement is determined by several factors.
for examples, ngk bp7hs, data 7, 7 represent this type spark plugs heat range.
