RCU Forums - View Single Post - YS63 engine vibrates plane at idle
Old 04-05-2004 | 10:12 PM
deputydog
Default RE: YS63 engine vibrates plane at idle
Joe;
Use the OS-F or YS plug. Also the motor tends to be a little rough at the low end until its completely broken in. Is your transition instantanious? You may need to slightly lean the low and mid range. Also what prop are you using? What spinner if any? And lasat but not least, what plane? Profiles tend to attenuate the vibration.
