RE: sanding control surface help needed
Where the heck do my posts keep going???? I answered this one hours ago. [:@]
OK, type it again.
What I do is make hinge blanks. For flat hinges, I cut 1/32" plywood the same size as the hinge. Round the corners so they go in easier. The blanks will help you a lot when it comes time to sand the parts to match.
For hinge points, I use the same size dowel as the hinge point. Has worked very well for me.
- Paul
