RCU Forums - View Single Post - Is something wrong with my evo
Old 04-06-2004 | 10:31 AM
Spaceclam's Avatar
Spaceclam
Default RE: Is something wrong with my evo
ok. during the power stroke of a two stroke engine, the fuel air mixture is compressed inside the crankcase. there may be a small hole somewhere or your front bearing is bad, causing the dense fuel air mixture to be forced out of the engine. If this is what it happening, you will not ruin your engine by running it that way, it will just loose abit of power and be a bit messier, but i reccomend having it looked at.
