RE: Tail Boom Vibration
this is normal sergey, it's just all the rotating parts like the spindle and the blades, settling into position under centrifugal force, as long as it goes away once your into hover rpm it's not a problem, also flying from concrete can make this problem worse, if you can try to find a grass patch to take off from, it will help alot
Gareth
