RCU Forums - View Single Post - 7CAP - lost endpoints after timer setup
Old 04-06-2004 | 06:11 PM
Hammer357
Default RE: 7CAP - lost endpoints after timer setup
Krysta
I have an 7CAP that produces the exact same endpoint/timer conflict as Adam mentions. The problem can be produced every time a 'timer' change is created and on any model selection. I have included the following radio setup information for your review:
Modulation: PPM
E.Point: CH1 100%/100%, CH2 100%/100%, CH3 80%/90%, CH4 110%/110%
All Other: Model Specific
On a related note, I don't think that the problem is limited to a few as there is evidence on another 7CAP radio at the field. We can reproduce the same 'glitch' on the other radio. Lucky for me, I discovered this problem on the ground and not in the air (limited the drama a bit).
It should be noted that it is a great radio for the buck, just have to remember the timer and end point issue before you go to the air. Even better, if there is a fix for this it would be greatly appreciated.
