RE: It can be done!!!!
I took steps to make it lighter. If you look at the photos, you can see the lightening holes in the ply fuse and the lightening holes in those slab ailerons. I did a few other little things here and there. I have seen these things come in near 10 pounds with a 120 4 stroke, so mine will come in at 10 pounds with the gasser. Hopefully, it will not fly heavy. These planes are floaters when under 10 pounds, so even if I come in a bit above that, it should be ok. No 3D stuff mind you, just a good solid airplane. I will keep you posted!
Tom
