RCU Forums - View Single Post - Flame out at full throttle
Old 04-07-2004 | 07:10 AM
pe reivers
Default RE: Flame out at full throttle
David,
Use a piece of thin solder wire to measure the room left between piston top and cylinder head in top dead centre.
If larger than 0.3mm, you might want to remove the head gasket to lower the head a bit.
