RE: Vector Flight Extra 300S 66" Build/Review
Bumstead,
Use the windex tip in the above post on the decals.... it's real easy.... I clean the surface (cowl or covering) with the windex first... let it dry.... next I spray the surface, don't soak it, just get it spotty wet... next I actually spray the back of the decal... just get it spotty wet.... place the decal close to the correct location.... it will slide easy... and it will wrap around the curved surface... once you are satisified, use a paper towel... work from the center of the decal out.... this squeege the liquid out, and dry the decal at the same time........ just take your time, and it will look great... It might be a good idea to start with the smaller decals, this will give you practice for the tougher decals that go on the cowl.
Good Luck.
