RCU Forums - View Single Post - When Should I balance a Kit?
Old 04-07-2004 | 03:31 PM
staggerwing's Avatar
staggerwing
Default RE: When Should I balance a Kit?
I usually build a small hatch into the rear of each plane. Then I finish it completely with everything installed. I then balance it. Put weight in the nose if needed there, or in the tail if needed there. The hatch allows me to change engines, etc and rebalance without tearing the plane a part to put weights in our out. Learned this from an old timer in the sixties and been doing it ever since.
