How do you seal the edges of monokote?
Be carefull of doing it that way. If you touch the applicator to the back of the monocoat the glue and
color are both gone. If you get enough on when you apply the stripes the edges should stick when you
push out the extra from underneth. Even so I have seen them try to peel. That's when I use an iron.
Put it on a low setting and just use the heel along the edge. Don't run it along the edge just set it down
pick it up and move it over. Using just the corner of the heel should keep any bubbles from popping up.
later daveo
