RCU Forums - View Single Post - So far, NOT so good!
Old 04-07-2004 | 10:45 PM
DBCherry
Default RE: So far, NOT so good!
What glue did you use on the horizontal and vertical stabs? Because if you used epoxy (and you should have), then it needs 24 hours to cure properly.
If you were using pinned hinges, you glued those in with epoxy too right? Because CA won't work with those.
Dennis-
