RCU Forums - View Single Post - About to take the jump on in
Old 04-07-2004 | 10:45 PM
LGM Graphix's Avatar
LGM Graphix
My Feedback: (22)
Default RE: About to take the jump on in
I don't know what engines you are looking at where the 12lb thrust class costs the same as the 28lb thrust class, but here are a couple things to consider.
A turbine is a pretty big investment in RC models no matter what the engine. Looking down the road to what you would really like to fly after your turbine trainer is done is worth doing and then decide what engine to buy. I really considered doing my F15 with twin PST600's as the cost for 2 of those is about the same as one P120, but after I get tired of the F15, I'll have 2 engines I'll probably never want to use again, as a result, I want a P120 instead.
Your cost in Jets isn't just in your initial purchase, you need to look ahead to your future with jets as well if you have limited funds. At our altitude I would consider something in an 18lb thrust class as a minimum. Even with a 12lb thrust engine, most 91 size ducted fans converted still won't do excellent off of grass with the extra weight. I have a couple of 91 sized airframes with 18 pound thrust engines in them. My Exocet is ballistic in the air, but to get off of my field, I'm really glad I have 18 pounds of thrust and I have about 800 feet of grass. My Kangaroo was actually tougher to take off just due to the thrust line characteristics of the Roo. My exocet will come off in about 200 feet, but that is with 18 pounds thrust. 12 pounds I would be a little hesitant on my field as there are fences at all ends.
At this point I think the best thing you can do is take a look at your budget and where you want to go in jets, then you can make a more educated decision on a lot of this stuff.
I'll send you a PM as well with my phone number and stuff.
Jeremy
