ORIGINAL: Frost_
ORIGINAL: ericheller
frost, i also understand your second post there, and that is why you need head shims. that happens often in glow engines because the glow plug is constantly "glowing". but by increaseing the nitro percentage and richening the motor you will increase compression ....
But hold up, that's not what you said, you stated that merely by changing to higher nitro changes compression. It does not.
well sorry for the misunderstanding but that is why it increases compression, is it not? i figured you all knew that when you change to a higher percentage you have to richen up the engine.
