ORIGINAL: MasterSmasher
Ha
Even if you make a hint you still get popups telling you to make a password
Freeware[:@]Freeware[:'(]Freeware[&:]Freeware[:@]Freeware[:'(]Freeware[&:]
this should not be the case. your password is already set. this is just a hint you set so if you forget your password the question will be asked to verify you are who you say you are. every credit card company or secure system typically uses this. Not sure why you are getting the popup asking you for a password or hint after it is set. that is not possible.
