RCU Forums - View Single Post - 7CAP - lost endpoints after timer setup
Old 04-09-2004 | 03:09 PM
mattalbr's Avatar
mattalbr
Default RE: 7CAP - lost endpoints after timer setup
I know the timer works without pressing the dial. My point is that pressing the dial allows you to specify at which stick position the timer kicks on or off. When you have the stick in position you want as a trigger point, you press the dial button. The default trigger location is about 50%. That's not keeping an accurate time of "on" throttle for me because I run electrics.
How about it?
