RCU Forums - View Single Post - YS 63 problems
Thread: YS 63 problems
Old 06-21-2002 | 08:57 PM
JoanC
Default YS 63 problems
No, I only use one filter. Do you think it is necessary to use a second filter between regulator and check valve? I have opened the engine and I have only seen a very small dirt in the regulator. Everything else semeed correct but I have not checked the check valve. I will clean it tomorrow before firing the engine and hope I have luck. I have also adjusted the valve clearance but donīt think that it was the reason of malfunctioning.
