RE: U Can Do 60
Deal me in, I'm back in the game. First a little history. This is a compilation of past UCDs. Rudder and tail wheel from #1. Wing, hor. stab. & elv. from #2 Canopy and landing gear from #3. New fuse, new cowl. Heres the list of goodies. JR-XP8103 TX, JR-R945 PCM duel conv. RX, 527 standard on throttle, DS811s on ail. & elv. DS8231 on rudder. 4/40 rods all round w/ swivel ball links. 5 cell 1700 mih NiCad. Saito 100 (old faithfull) swinging a 16/4 APC prop. The prop is analy balanced (hours) and yes.....I balanced the true turn spinner as well. You would be suprised as to how much they are off balance. "Dubro" pinned hinges. Stock composit engine mount on "Ernst" thrust plates. 3 degrees to start and I'm leaving the cowl off until the thrust is dialed in including up/down thrust if needed. Tank on the CG (5 5/8) with a "Cline" regulator. Laterally balanced. Will post the weight when time permits.
