SOMETHING IS WRONG, PLEASE ADVISE
I've just fitted a set of Kyosho ally clutch shoes with 1.1 springs to a Kyosho 3 shoe flywheel and something aint right. The tips of the springs touch the coiled section of the spring in front which prevents the shoes from resting on the flywheel nut. It's like the spring tips are too long. I can lift the shoes for about 2cm before the spring tension takes hold. I've run the car and the shoes are not binding but I know things are not correct. Bill61 has tried to help but has come to a dead end. It is not bad springs or the wrong flywheel as I noticed the same thing last week when I replaced the clutch shoes on another car. I must be doing something real dumb. Can somebody give me any help please?
