RCU Forums - View Single Post - pull start ?
Thread: pull start ?
Old 04-10-2004 | 01:01 PM
ericheller's Avatar
ericheller
Default RE: pull start ?
ORIGINAL: Mxracer45
Yes you can take the pull start offf and start it with a drill.......... but its the most horrinble way ever to start your engine. ALso dirt will get up in there and your screwed
dirt will get in where, the engine? thats not possible unless its getting in your intake or your manually putting it inside of you engine.
^^_FaWaZ_^^ - i think the pump your refering to must be a primer and if so that is not to start the engine, it simply gets the fuel to the engine without dry starting it.
