RCU Forums - View Single Post - JR Matchboxes
Old 04-10-2004 | 07:07 PM
pilott28
My Feedback: (27)
Default RE: JR Matchboxes
ORIGINAL: David Gladwin
If using two servos on one critical flight control, via a matchbox, it can be argued that it is better to feed one servo DIRECT from the receiver and trim the other or others via the Matchbox. Thus if the Matchbox should fail, then one servo remains operational.
Having said that, I have never had a Matchbox fail, however, the possibility exists so routeing BOTH servos via Matchbox does not seem to be good practice.
Regards,
David Gladwin
This kinda defeats one of the reasons to use a matchbox -- mixing multple servos into a single channel on the receiver.
I agree with Bob Covish. I use them on flaps and rudder but avoid them on elevator when I can. Aileron installs normally work well with a Y harness so there is no need for additional mixing.
Regards, Keith.
