RCU Forums - View Single Post - G26 goes dead please help !!!!!
Old 04-10-2004 | 07:34 PM
coony2787's Avatar
coony2787
My Feedback: (33)
Default RE: G26 goes dead please help !!!!!
Well i belive i got it fixed , i did about 30 take off and landings and no dead sticks.
This morning i rebuilt the pump side of the carberator. I ran it after this and found that the fuel tank was absorbing alot of the vibration from the motor, i put foam around and under the tank to help with this ( not sure fuel foam will afect a gas like it will a glow). I checked the spark plug and cleaned it.
Went back out to the feild this afternoon. The motor ran worse and had no power []. I did not do must adjusting to the carb after all this work on it so i went back to factory starting specs. Whalla the engine preformed perfectly with just a few tweeks for final adjustment.
I sure do appreciate all the help you guys put in. I believe with you all's help the motor is now preforming properly. However i'am not real sure as exaclty what fixed the problem. thanks everyone !
Chad
