RE: Need help with H9 1/3 cap
I am assembling one now also. I just moved the location over a little to get the horn on the hardwood and I drilled perpendicular as the instructions say to do. When you tighten up the nut, it will compress the wood a little and sit flush on the surface. No big deal. I also suggest putting a little ca glue on the nut to keep it secured.
Jim
