RE: Time for a new glow plug?
The usual symptoms of a bad plug are the engine slows down when you remove the ignitor battery and/or the engine won't idle without dying. Just because it glows doesn't necessarily mean it is good. If the filiment has been contaminated it may still glow with external power applied but, the alcohol does not make enough contact with the element to permit the catalytic reaction required to keep the engine running.
