RCU Forums - View Single Post - how fast is the aerobird?
Old 07-30-2003 | 06:52 AM
aeajr's Avatar
aeajr
Default how fast is the aerobird?
Repairing an Aerobird wing with packing tape doesn't really work very well if htere is a crease. It might fly, but at the first real stress, its gonna fold and you are going to crash.
The tape has no body or stiffness of its own and the folded area of the wing has had the foam compressed. Net Net, nothing to resist the next fold. If you open the vinyl and fill the crease with something that is stiff you can get pretty good results, but it is tricky. I tried building foam from a can that you use to seal around windows. Works OK, but very messy.
A better solution is to get something thin but stiff, like a strip piece of wood, but balsa is probably too soft. 1/16th or 1/32 ply, if such a thin ply exists, or a thin piece of plastic would work. Bond it to the wind with double sided tape. A 1" wide piece of plexiglass that is thin might work. It can flex, in fact a bit of flex is good, but it must resist folding. I would say 8" wide would be the minimum width I would suggest, and I would go 2/3-3/4 the length of the wing, say 25" to 30", as a recommendation. Be sure to center it left and right so you don't unbalnce the wing. The bird can handle the weight of a light piece of plastic or wood. I have also seen wood dowels or carbon rods used. Anything that will resist the folding of the wing.
Attach it to the wing with doublesided carpet tape or something that will bond it to the wing. Then use packing tape on top of it to smooth out the air flow. Stretch the tape to create a smooth surface rather than fitting it tight around the edges of the strip or dowel.
If you look at the Firebird XL wing, it has a carbon rod embedded into it when you buy it. Other similar planes, like the T-hawk, have these supports in their wings when they are new.
Give it a try. Don't depend on the tape to keep the crease from folding again.
I may add a support to my new wings from now on.
