RE: U-Can-Do 3d 46?
Guys I have a question on setting up the wing, I set up the first wing with the ailerons centered between the top and bottom of the wing, I popped a hole in that one and built another wing with the ailerons set flat with the fuse on a recommendation from a supposed 3D guru, I crashed with the wings set like that so I am hesitant in setting it up this way again, but if it's right I need to know....what have some of you guys done???????
Mike Hoffman
